im running Transynd in my allison 1000 6 speed. it is expensive to do the initial fill but will likely last as ong as you hve the bus. ive added very little to the transmission in the nearly 3 years since i did the swap.. likely just what ive lost changing the spin-on filter each year, so once you make the initial investment you shouldnt have to spend much to keep it full unless you break something where the fluid is lost.
Looking through the approved Allison fluids list (TES295), the best deal I found locally was Castrol BP Autran (green bucket). This was at NAPA in a 5 gallon pail. I forget the exact price difference, but compared to either Transynd or Mobil Delvac from the same store, it was a smoking deal (and not a sale price). Not sure if this holds true in other locales or from other suppliers, though.
I've read, but can't confirm, that it's exactly the same fluid as Transynd. Does anyone have further info on this?
