Originally Posted by s2mikon
If the shifter linkage goes out of adjustment it WILL burn up the foward clutches and leave you with reverse and 5 neutrals.
what he said.. if the linkage was bad prior it causes an internal fluid leak which reduces line pressure in an already line-pressure deficient transmission...
I still find Master kits all over the internet for these.
you can also buy them reman by OE.. most of these are RenEwed by Navistar Diesel shift points for 2600 RPM.. there are different part numbers you can look for the one you need..
by the time you buy a master kit and rebuild one yourself you can have one of these with converter installed and be rolling..
I bought a 643 from these guys 3 years ago and zero issues.
https://lkqheavytruck.com/inventory/...UILT%20BY%20OE
