Originally Posted by turf
nothing regular about me
as far as i know
the 545 shifts on an rpm range. if you are governed at 2400 rpm then
the 1-2 shift is around 600 rpm
the 2-3 shift is around 900 rpm
the 3-4 shift is around 1500 rpm
if yours is ahifting like that then you likely have a bad or misadjusted modulator
the speed at which a 545 shifts is highly dependent on the rest of your driveline.. most generallly if you floor one it should go close to 2600 RPM on your engine before it goes to the next gear..
with an 'E' engine there is only 2 shift point adjustements (low and high)... the electric modulator is designed so that if you piut the engine under load or your speed drops low that the computer activates it.. these are known to fail and will prematruely destroy your tramnsmission if they fail in the off position.
if the modulator is failed in ther office position you'll notice it always seems to shift early even if you have your pedal floored ..
to test your modulator there are 2 ways.
1. drive at very light throttle on flat ground and note when it goes into 2 and 3.. you can take it up to 4 but may take you a bit as you accelerate slowly..
pay attention to the MPH that it shifts at light throttle.. not the RPM so much although the RPM should be in the 1500-2000 range..
now take it out on the same road and floor it .. yoiu should note a much higher RPM and faster MPH speeds at each shift... close to 2600 RPM.
another way to test the modulator is to drive at light throttle till it shifts to 4th gear than immediately floor it after the shift.. it should downshift back to 3rd and go up higher in MPH than it did during light throttle..
with there being no lockup converter on an AT545 you wont really feel solid hard shifts although the shifting is definitely going to feel rougher than your average car (unless you have a muscle car with a transmission)..
your shift feel is going to be a 'back and forth' type motion as most of the shifts in the 545 are releasing a clutch pack and then grabbing another.. I believe 1-2 is the harshest due to the clutching sequence.. and its also the noisiest too with the distinct AT545 whine present going from 1-2.
the shift timing should always be in the less than 1 second range for 1-2 and 2-3, 3-4 should be pretty quick.. meaning watch your tech and it when floored you should see it drop fairly quickly as it goes to the next gear.. although the number of RPM it drops wont be particularly high because of the no-lockup but it should not be a 'slow-slide' from one gear to another..
