Old 01-13-2024, 08:42 PM   #1
Axle width help
I知 building a project basically I知 taking the bus body off and putting a different kind of body on it. But I知 needing some measurements on the rear and front axles. Hub to hub?
Bfoulk is offline   Reply With Quote
Old 01-14-2024, 06:10 AM   #2
La Camioneta's Avatar
Year: 1994
Chassis: Ford B-700
Engine: 12V 5.9
Could you be less specific, please?
La Camioneta is offline   Reply With Quote
Old 01-14-2024, 09:47 AM   #3
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
I'm filing this away for future use!
PorchDog is offline   Reply With Quote
Old 01-14-2024, 10:10 AM   #4
Found this. Class B and Class C will have a track width (rear dual wheel) of about 75 in. Front track widt of 85 in. Over all vehicle width should be 95 to 102 in.
Old 01-14-2024, 12:54 PM   #5
ewo1's Avatar
Hey new guy, welcome to the madness but please don't make it crazier than what it is!
Tell us about your project and just what is it that your trying top build?
There are quite a few engineers here so tell us what your doing and you might get some real good help!
ewo1 is online now   Reply With Quote
Old 01-14-2024, 01:16 PM   #6
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
OP it will be more manufacturer specific.
what you working with and what are you trying to do.
Old 01-14-2024, 02:12 PM   #7
This is what info I’m needing in measurements and also for the front!
https://www.imghippo.com/i/1705262926.jpg
Old 01-14-2024, 02:15 PM   #8
This is the info I知 needing in measurements and also for the front.
Old 01-14-2024, 02:18 PM   #9
ewo1's Avatar
What are you building?
Old 01-14-2024, 02:22 PM   #10
Putting a military cab on a bus frame
Old 01-14-2024, 02:32 PM   #11
ewo1's Avatar
Now that sounds like fun!
Why is the axle measurements so important?
Cab should fit up on a bus frame and clear the wheels no problem?
Got pics of the cab?
Old 01-14-2024, 02:33 PM   #12
I’m building a bed with fenders. No pics
Old 01-14-2024, 02:42 PM   #13
Year: 86
Chassis: Ford B700
Engine: 8.2
ok axle manufacturs vary with brand age and tire size as well as military axles.
manufacturers have id tags and serial numbers with gear ratio size.
perch mounts can be changed.
if you have the axle then why not just measure it?
if you dont then figure out the specs of the axle you want to get.
a school bus axle and a military 5-7-1/2 ton axle are completely different aspects including the springs.
Old 01-14-2024, 02:54 PM   #14
ewo1's Avatar
What bus frame you using?
Engine/trans?
This summer I am gonna swap out a 1979 F600 and put it on a bus chassis.
Searching for a cheap bus now.
Looking for a DT466/250 hp mated to an MD3060.
Old 01-14-2024, 02:58 PM   #15
I don’t have a bus yet. I’m wanting to get one with a cat 3126
Old 01-15-2024, 12:20 AM   #16
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
✈Welcome to Fantasy Island
Yes! Military cab on a bus frame... I'm into it. Reminds me of JoeBlack5's Unimog Conversion (search) and this oldie⤵
MilitaryTrader.com/More-Than-Just-a-Bus
Remembering the AFKX-352 Ordnance Shop Van
D. Doyle May 2022
I like a mobile shop.
Work benches w/ overhead lights & receptacles. (All Steel conduit)
Electric panel for municipal/generator. All 1940 factory spec.
Rear Entry
6x6 drive axles
To read more about the 1940s GMC AFKX-352 Small-Arms Repair Trucks, click the link above. Lots more photos, too.
Bfoulk,
Show us what parts of your project which you have assembled or completed, thus far.
🙋 With what tools & materials are you currently working? Paper-n-pencil, keyboard, wood, steel, 🧠 imagination?
🇺🇸 Frederick Douglass: "If there is no struggle, there is no progress.
Old 02-14-2024, 11:59 AM   #17
Axle width help
anybody has other measurements on different buses feel free to chime in.
Old 02-14-2024, 12:44 PM   #18
ewo1's Avatar
So to answer your general question in a "general " manner, typical track width on a bus rear axle could be between 70-80 inches. It really depends on the specific axle being used.
Go to THIS THREAD, post #6 and you will find a link to a spicer manual that indicates track widths on the various spicer/dana axles.
Most, if not all, international busses will have a spicer/dana axle.
BTW, looks like a really cool project!
