Brakes not releasing
I went to move my 2004 international into the shop Saturday to avoid it being buried in snow and the brakes were not releasing. At first I had thought it was slightly sunk into the ground, so I gave it a bit of gas and it moved slightly and then stopped. I was able to struggle it into the shop as it was only about 50 feet away, once parked and turned off the brake lights remained on as if the brake pedal was being pressed. Stuck my toe under the pedal and it moved up, and the lights went off.
Has anyone ever experienced anything like this?
Should the air pressure remain up while the bus has been sitting for a long time? When I started it, it was in the red and beeping, and slowly built back up over 1-2 minutes.
