Originally Posted by Dirtdoctor
Never less? It should be around 120psi. I’d inspect and do a R&R on the whole air system. What’s your leak down test look like?
its quite normal for the air pressure to cycle between 90 or 100 and 120 or 130. the governor has a deadband on it.. most D2 governers asre designed at 90 on and 120 off so you quite frequently see air pressure in those ranges.
if you have an air dryer designed to use wet-tank air as purger (some of the wabco do) or have a bad check valve.. then you'll see your air sit constant at 120 and hear the purge every 30 seconds or so.. thats a system which should have attention..
otherwise 90 is as low ass it should go unless you made a panic stop where you have air ABS that engaged.. then it might be a little lower..
and of course at start-up after the system has lost all its air..
