Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-11-2021, 08:51 PM   #1
Year: 2005
Chassis: IC PB10500 CE300
Rated Cap: 48
Broke both rear shocks off
Was driving for the past 2 days, noticed the bus was bouncing a lot more than usual.
Looked under the bus at the rear shocks and the top bolt of one and the bottom bolt of the other was sheared off.
What do you supposed caused that.
I just had the shocks replaced 2 months ago. The shop put Monroe shocks on.
Kevin
kevinstotz is offline   Reply With Quote
Old 10-11-2021, 09:38 PM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
The shock is
Too long or too short.
In other words,,, it is the wrong shock.
Or perhaps you are missing a bump stop.
My bet is wrong part.
William
Old 10-11-2021, 09:40 PM   #3
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Not enough air in the shock. Causing it to bottom out (hard).
Pivot bolt not torqued. Too much play can cause a break.
Or just the wrong shocks, as William suggested.
I attached a list of Monroe school bus shocks which may be helpful in identifying whether or not the parts installed are correct.
Frederick Douglass: "A man is worked upon by what he works on. He may carve out his circumstances, but his circumstances will carve him out as well. - I didn't know I was a slave until I found out I couldn't do the things I wanted.Ē
Old 10-11-2021, 10:56 PM   #4
sportyrick's Avatar
Chassis: F33695
I vote wrong shocks. see if they have the old ones and do some detective work, you shouldn't be liable and have to purchase new ones they do.
Old 10-11-2021, 11:28 PM   #5
Year: 2005
Rated Cap: 48
I left that service shop a few months ago in cape cod
Old 10-11-2021, 11:28 PM   #6
Year: 2005
Rated Cap: 48
Thanks...I'll check in the am
Old 10-12-2021, 09:03 AM   #7
Engine: Navistar 7.6L
That pdf does not list air shocks.
Not surprising as shock mounts are not built to be load bearing components of the suspension. That is true for most vehicles.
It amazes me that some ambulance chaser has not sued the air shock sellers out of the business of selling them.
DoubleO7 is offline   Reply With Quote
Old 10-12-2021, 12:26 PM   #8
Year: 2005
Rated Cap: 48
As it turns out, the shop in cape cod installed the wrong shocks.
That cost me $1200 for new shocks and a shock mount
Old 10-12-2021, 05:55 PM   #9
Rwnielsen's Avatar
Chassis: TC1000, 40' MPV
Rated Cap: U/K
I would stay in touch with that shop, maybe head out that way when the weather improves. That $1200 is on them
Rwnielsen is offline   Reply With Quote
Old 10-12-2021, 07:21 PM   #10
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
GD!
$shocks are what? less than $100 a piece last I looked.
Install time is what? 5 mins each, last I did them.
That is one hellava shock mount.
Look at the Sky; look at the River. Isn't it Good?
Old 10-12-2021, 07:29 PM   #11
I'd be filing a suit right about now.
Old 10-12-2021, 07:31 PM   #12
Year: 2005
Rated Cap: 48
Originally Posted by Mountain Gnome View Post
GD!
Ya. It's expensive..
Old 10-12-2021, 08:34 PM   #13
Shocks were an hour job on my dev bus when I got it and they were rusty crusty been on for 20 years look!! And still only an hour
Old 10-12-2021, 08:38 PM   #14
Year: 2005
Rated Cap: 48
Ya. It's a typical scenario..
The bolts sheared off. Stuck in the support and upper mount.
I could drill and work them out. But doing so in a park is not real nice place to work.
We have been on the road for 5 months.
I am Capturing j1939 data though.
Priorities.
Kevin
Old 10-17-2021, 05:09 PM   #15
If it’s airbag suspension, if you don’t let the bags fully inflate you will bust off the shocks.
Unless the wrong shocks were installed. But if the bags don’t fully inflate you will bust the shocks.
Dirtdoctor is offline   Reply With Quote
Old 10-17-2021, 05:15 PM   #16
Year: 2005
Rated Cap: 48
Hmmm...how does one know if the bags are fully inflated?
The CIT trucking said the wrong shocks were installed.
Old 10-17-2021, 07:19 PM   #17
Run the air compressor up to 100 Lbs and climb u fee the bus amd look at them. At 60 psi the alarm stops, sure you can drive but the bags won’t be fully inflated.
Old 10-17-2021, 08:27 PM   #18
the bags dont even start to inflate until the alarm stops (if the protection valve is working like its supposed to)
Old 10-17-2021, 10:49 PM   #19
Year: 2005
Rated Cap: 48
Ah, yes, if that's the case, then the bags were full. The air pressure is never less than 90 while I'm driving
Old 10-18-2021, 06:12 AM   #20
Never less? It should be around 120psi. I’d inspect and do a R&R on the whole air system. What’s your leak down test look like?
