06-15-2020, 11:27 AM
Chassis: YouTube @ Sojourn Expedition
Buying a Bus / CAT vs. Cummins
I'm looking at a Bus to convert. It's a 33ft Blue Bird for $3600. It's a southern bus, so it has very little rust. The Transmission is an Allison 2000 Series, which seems fine, but the motor is a Rear Compartment CAT 3126. I'm just not sure about the Cat 3126. I'm waiting on the maintenance report, but it seems like some people on this forum are down on CAT motors. I'd really like to know some specific reasons. I know some have mentioned that the repairs are pricey, but most of those were not rear compartment engines. Does that make a difference? Are there other considerations?
Also, I have found other buses to buy. They have Cummins engines, but they also have the Allison 545. Is the 545 that bad? How much would it cost to switch it out for a 643? Is it worth it?
06-15-2020, 12:11 PM
Cat 3126 is a darn good motor. COupled with an A2000 you've got a smooth, quiet running setup with good mpg's.
Don't let anyone scare you away from a clean well maintained 3126.
Repairs don't cost any more than any other medium duty engine.
06-15-2020, 05:18 PM
Engine: 345 international V-8
Cat 3126 seems to be decent, the Cat C7 is a problem child.
Changing transmissions is not an easy task unless you are used to doing it. Even then it takes some time and skill. I would take the 3126 and allison 2000 before the cummins and 545. Even though in general I prefer the cummins.
06-15-2020, 06:20 PM
I agree with Ronnie on this one.
All engines will be cared for differently in their lifetime so Op, how well do you know diesel characteristics and do you enjoy learning and wrenching.
If not then expect some heavy repair bills if any shop has to do it. You might get lucky if you have family or friends to assist you and just about every conceivable problem has already been discussed here so reading is a must.
People can only be so helpful here, experts or not and each bus has its own quirks and gremlins, so be very wary. Being there in person is a lot more helpful for trained techs than all the knowledge they can pass on thru this site.
Understanding is key but being able to use tools is all important. A lot of problems can be caught ahead of time and avoid major repairs.
It's all up to you.
As mentioned I like Cats due to design and layout compared to other engines. ymmv.
06-15-2020, 06:49 PM
Engine: 8.3 Cummins ISC
Rated Cap: 75
I am not a fan of HEUI engines in general, Cummins is much better when it comes to injector/pump design. Not a deal breaker but something to consider.
Also the fact that Caterpillar has not made an engine for the on-road diesel market since 2008 is also something that needs to be considered. As time goes on (especially in Rust Belt areas) the number of CAT powered trucks & buses is only going to diminish which means parts availability and mechanical knowledge is going to suffer.
I still enjoyed driving the 2 2008 CAT C7 Bluebird AA FEs we had at my company the first few years I was there. They had a lot more power than the rest of the fleet and I never had an issue with them (although fleet operated school buses is a VERY different scenario than a skoolie application).
06-15-2020, 07:21 PM
none of us are running engines much newer that 08. and only cummins is still building medium duty diesels.
ANY pre-2004 engine is about the same in terms of parts availability and service.
I'm having a much better time owning this Cat than any of the Navistars before it, although the mechanical DT466 I had was marvelous.
Ford vs Chevy for all the pre 2004 stuff.
06-15-2020, 09:58 PM
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
As you can see OP, CAT vs Cummins is about like asking Ford vs Chevy. Sure people have their preference and some can even explain why they prefer one over the other. For our purposes here, most of us know little to nothing about diesel engines and most of it is secondhand not firsthand personal experience so the reasoning for preferring any one over another is practically irrelevant. WIbluebird brought up the only actual definable difference with the HEUI injection system but I'm guessing half of us don't even know what that means anyways. Unless you're already a diesel mechanic and know why a CAT or a Cummins might be better for you it's unlikely that this is going to be the make-or-break factor for you. It's also far more likely that whatever you end up with if you're the type who likes to learn all you can about your own stuff you'll likely develop an affinity for your type and thus you'll either be a CAT person or a Cummins person! See how that works?!
By all means the real make-or-break factor here is the transmission. Avoid an AT545 as much as possible and if you have an alternative available that right there should probably be your deciding factor. Engine or transmission swaps are huge tasks with huge expenses and huge headaches unless it's just the type of thing you already do in your spare time and therefore know what you're getting into.
06-16-2020, 11:39 AM
So turns out he doesn't have maintenance records, and the dashboard doesn't work. He has some type of documentation stating the mileage was 125,000 at purchase. Any thoughts?
Is there a way to pull up public records if he bought it from a public school?
06-16-2020, 11:49 AM
Doubtful.
Gonna have to go on condition. Check out his "documentation".
06-16-2020, 08:58 PM
If it's a CAT engine a CAT service tech can read the engine computer and tell you quite a bit. exactly how many hours it's operated, any trouble codes past/present, .
You'll receive a printout from the diagnostic computer checkup...
I don't know what the charge is but call round and see --
If the owner refuses to allow it then you know something might be wrong...
06-17-2020, 06:35 AM
Chassis: BlueBird
Engine: 5.9 24v
Enter the vin in Bluebirds Portal and you'll get some info, especially who the original purchaser was. One thing I watch is the rear end ratio, those are expensive to swap if you want highway speeds and lower rpms.
Clusters are also expensive if you have to purchase one.
Definitely get a tech to scan the ecm - since the dash doesn't work do the idiot lights?
FYI - there is a RE Thomas with the 3126 here in Atlanta that needs an injector, guy is asking $2575. Should still be on MarketPlace if you want a comparison.
06-24-2020, 03:29 PM
The AT545 is okay if you don't mind the fuel mpg decrease.
06-24-2020, 09:15 PM
Chassis: Thomas
Rated Cap: 8 seats, 5 wheelchairs
But Cat is still building the 7.2 engine in an off road version and it goes in a lot of excavators, loaders, etc.. Parts for our 3126's shouldn't be a problem as long as Cat doesn't just go completely belly up and out of business.
06-24-2020, 10:05 PM
Cat quit making over the road diesel engines to avoid meeting the new emissions standards in 2008. The 3126 is a good engine like most diesel engines will last a longtime with proper service and maintenance.
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"
06-24-2020, 10:21 PM
There's also the higher operating temps and lack of engine braking.
06-24-2020, 10:23 PM
I've had no issues getting parts other than I had to go to the parts store for a generic v belt cause the freightliner shop was out of em.
06-25-2020, 04:57 AM
Chassis: Ford F53
My company hauls way too much CAT parts for them to be in danger of going out of business anytime soon. Granted they did tighten up their logistics chain for more efficiency which resulted in fewer actual truckloads but that's just good fiscal business and not a sign of trouble.
I also don't think people realize how vast CAT's international market is. I have no numbers to offer but I know much of what we haul is bound for overseas. Any emerging nation or developing overseas industry usually needs earthmoving equipment and global CAT is a well respected name. Departing the Class 5-8 diesel engine market was probably barely a blip on their balance sheet.
06-25-2020, 08:39 PM
Chassis: Thomas
Cat is a heavy equipment manufacturer, always has been, the highway engine line was just a sideline venture for them. A lot of people think that it was a "big deal" because Cat quit making engines. Well no they didn't, they quit a sideline deal that the EPA made it more difficult than it was worth to maintain.
06-25-2020, 09:10 PM
I really do think it was best they got out when they did.
06-26-2020, 01:05 AM
It says a lot about the company that it knows the market and business environment and can adjust as needed like it has.
