the ford / IH 7.3, 6.0 are also HEUI engines.. maybe the cat HPOP is different? I think almost no one runs a filter Post HPOP is that HPOP failure with schrapnel is something I almost never hear about.. wearing HPOP that eventually fails to build the required pressures is something that does happen.. esp in situations where guys are running performance tuners and injectors that require the HPOP to run near flat out all the time..
There are a few differences between the cat and IH designs. The heui pump in the IH engines is a fixed displacement with a pwm controlled valve to regulate pressure. Whereas cat used a variable displacement pump with a bleed orifice.
The IH pumps very rarely lunch themselves, they're much more simple and
very rarely send shrapnel through the system. If they do, I think the injectors have screens on the oil inlet to prevent ingestion of said metal.
The last ford/IH pump that I replaced was because the internal swash plate, which was supposed to be held by a press fit, rotated 90 degrees. This caused the intake and delivery ports to be out of time with the pumping action, which caused the pump to no longer pump.
Cat pumps, being variable displacement, are more complicated. They have more moving parts and will lunch themselves, sending shrapnel through the system. The injectors also don't have inlet screens, so they will ingest metal and become ruined if shrapnel is present.
I won't say trashed heui pumps are a common problem with cats. But normally, if a repair requires replacing the pump, it will also include injector replacement.
assuming it doesnt cause any flow restrictions or back pressure on the pump when the filter starts tio get dirty then it sure seems like it cant hurt.. I would however want to keep both the main oil filters and the HPOP filter siminlar in filtration size (microns). or replace them all during every oil change.. or is the HEUI filter desaigned with a larger particle pass-through and just a protection against pump metals and not oil contaminents?
I think it's more of a metal mesh screen then a high efficiency filter. There is an indicator to show when it's full, and when it is full, they do have replaceable elements. Not sure if you can clean the old ones or not. Oil contaminants should be caught by the primary oil filter, so if you're getting contaminants into this unit, you're not changing your filters often enough.
