Hi all, my FE Thomas bus has a small glass(?) bulb at the top of the radiator that's supposed to be used to check the coolant level. First of all, the bulb is kind of dirty so it's hard to actually see the coolant level, but second, I noticed today that it seems to be leaking a little bit of coolant from the bottom of the bulb. The weird thing is I haven't started the bus in a week, so I'm not sure why it would be actively leaking now?
Here's a pic of the bulb I took previously, I can get a new pic with the leak shown later today. It's a very small leak, just a few drops, enough to leave a little bit of a wet spot at the top of the radiator.
What's also interesting is that this leak didn't start until after I ran the bus last, which was just idling in the driveway for about 30 minutes while I tested the air system a bit.
