Originally Posted by Therese
Hey Gang-
I hope y'all are doing well.
I did a search for other coolant and heater removal threads and did get some info but it only brought up more questions.
We were going to remove our rear heaters and I thought that the valve with separates the engine system from the rest was in the closed position but I ended up with over five gallons of antifreeze so it obviously was not.
First question: Is there a sticker somewhere on the engine which says what kind to fill up with?
Second question: What the heck is air lock in respect to the coolant system?
That's it really. I mean I wish the heat wave would go away so I could stay out longer and get more accomplished.
All my best
Therese
Not knowing your bus, front engine, rear engine, length, etc., it's hard to tell just how much coolant would be in your heater hose lines and your heaters. Yet, 5 gallons is a lot!
Most of the time, you go by the color of the coolant that came out of the system.
You really should get the VIN of your bus or the engine and contact the dealer to determine what can and can't be used. For example, the T444E before about June of I think 1997 (99?) used green, yet, just a few short months later it could also use extended life (red I think) coolant.
Per air lock, here is the result from a quick search:
What is a coolant air lock?
Simply put, it is the presence of air bubbles inside the cooling system. Even a small amount can create air pockets which prevents proper circulation of coolant. Signs and symptoms of radiator airlock include: Overheating during normal driving. Heater not functioning correctly.
