Correctly Measure Allison MD3060 Gear Oil +Check Trans
Hello, everyone.
We are new to our Cummins 8.3 Pusher with Allison MD3060 transmission. For a short time now, the CheckTrans lamp in the cockpit has been on when I turn the key. When the engine is running, the lamp is off again. I checked the oil level with the engine stopped. then I can see pink oil on the dipstick. But when the engine is running and I measure, there is nothing left on the dipstick. Is that normal? Or does Check trans indicate that the oil level is too low?
Thanks very much
