Changing an air filter should be about the easiest maintenance item on a bus, but I'm embarrassingly stumped by this. Here's a picture of the filter compartment on the driver's side of the bus, just behind the engine:
There are four main parts here: the filter box on the left, the box cover that I'm holding on the right, a bottom plate that I had already removed for this picture, and the filter element itself (still inside the box in this pic).
From the picture, it looks like I should be able to easily pull the box cover out of the bus, swap out the filter elements, then reassemble. What you don't see in the pic is a drain vent of some kind that sticks down from the box cover several inches and makes it so that no matter how I try, I cannot get that damned cover out of the bus! I wrestled with that thing for 1/2 hour with no luck. Fortunately, I was able to inspect the old filter with a camera and it looks fine for now, but someday I'll need to change it.
FYI, the three bolts/nuts on the left of the pic have not been removed since it left the factory, yet the filter was supposedly replaced in 2020. Those and their extremely hard-to-reach cousins on the back of the filter box will be my last resort, but I'm thinking there has to be a better way.
Crown experts, what's the trick here? Everything else on this bus is well thought-out and relatively easy to access, so I must be missing something!
