Crud/oil in air brake tanks/lines
Bus:
1986 Chevy B6000
366cu in/6.0L V8
GAS
5 speed manual
My bus has 2 air tanks. The biggest is towards the front, driver side. Smaller behind the rear axles.
1. On each tank is a "key" thing that I can manually turn (pic). When I turn the keys, air rapidly shoots out of the tanks. When I barely turn the key, this goopy, brown, oil smelling stuff comes out. It comes out as long as I have the key turned. What is this gunk? Surely, there shouldn't be anything but air in these tanks, correct? How did this goop get in there? What IS the goop? WHY does it smell like oil?
2. On the front tank, in addition to the key valve, there is another purge valve of sorts near the bottom of the tank. ( pic). When I pulled on the cable that releases the valve, the same brown goopy stuff FLEW out. And it just kept coming, probably close to 500ml came out, gooey, gross, oil smell, all over my hand, then I just closed it.
WHAT is this? It's not supposed to be there, correct? Do I just keep purging the valve until that crap doesn't come out anymore?
What's the procedure for air brake purging/maintenance? Certain order of operations I need to follow? Specific steps I should take? Other maintenance to do? These aren't auto adjusting, I recently adjusted the slack out of them. But what else to do? Thanks
