Old 05-26-2021, 04:46 PM   #1
Coachwork: Blue Bird All American
Rated Cap: 2 adults and two pigeons
Cruisario control
So finely said in a Spanish tone! Curious if cruise control can be added to my 2003 AARE 8.3? Also can a Jake brake be done to it? I haven't got that far into the build but planning stuff out.
--Simon
Found my Bus at AAAbus in Phx!
Bus'n it is online now   Reply With Quote
Old 06-12-2021, 11:21 PM   #2
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
If you do a search on this site for "add cruise control" you'll find a bunch of links to other threads on this subject. Your answers are probably in those threads.
Per the jake brake, I'm not sure. You'll have to talk to Jake. Sorry, I didn't know the answer and was being a wise ass.
Depending on your tranny, you may have some retarder type aspects already. If so, the jake brake may be redundant.
Good luck on the cruise control. I was sooooo happy when I turned my on in the ECM and it worked!
Steve
Old 06-13-2021, 12:09 AM   #3
I've got a buddy with an ambulance with the Cummins 8.3 and he bought OEM cruise control switches (there were two) and plugged them into the harness and it worked. In his case, the cruise function was active in the ECM. I have NO idea how common this is... I defer to Steve on this, as he actually made the addition.
Old 06-13-2021, 11:52 AM   #4
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
Jake brakes can only be fitted to heavy-duty engines. I've never seen or heard of a Jake for a Cummins 8.3 (or CT or CTA), so was it an option? The big 14-liter Cummins NH-series that Crown and Gillig used could have Jakes, along with all the Detroit engines, but lighter-duty engines such as the Cat 3208 and smaller Cummins could not use Jakes. How about using a Telma instead? Isn't there also a Spanish company that makes an electromagnetic retarder like a Telma?
Old 06-13-2021, 10:07 PM   #5
Simplicity's Avatar
I watched this video about the Telma and was wondering how the excess electricity could be used to charge house batteries?
I guess you basically have to have your driveshaft resized to allow for the retarder. Pretty cool.
Steve
Old 06-14-2021, 10:57 PM   #6
Coachwork: integral
What excess electricity? Any electromagnetic retarder like a Telma will require a very healthy large alternator to power it, but heavy-duty vehicles usually have them anyway. A Telma doesn't produce electricity like the dynamic brakes on a locomotive; it uses power to produce eddy currents in coils that slow rotors between them by induction (or something like that!). The resultant mechanical resistance becomes heat, just like from any other braking system, but all this heat is harmlessly dissipated into the air flowing under the vehicle.
Old 06-15-2021, 12:06 AM   #7
Simplicity's Avatar
Heat is energy. Regenerative braking uses heat to keep batteries charged. The amount of electricity used to activate the magnets could partially, maybe fully, be recaptured?
So, maybe they are not capturing / converting whatever energy is created during the retarding, but I'm pretty sure it could.
Why not?
Steve
Old 06-22-2021, 06:50 PM   #8
Coachwork: integral
Please explain.
Old 06-22-2021, 07:08 PM   #9
I didnt think the Telma is a motor, I thought the magnetics are actually to create extra resistance.. i dont think there is a stator and rotor tuned to be a reverse force but a force that on a motor would result in a locked rotor which uses energy not creates it..
i think there were some retarders that were essentially dynamic braking motors that had large resistor packs to dissipate the energy.. I didnt watch the video but thought the telma is a different principle
Old 06-22-2021, 08:17 PM   #10
Yeah, but the cost to figure out and install mountings for that may make it a moot point. I was hoping I could just fit an engine brake. Love my engine brake on my Laramie truck. It never gets turned off! (I have to remember to turn it on every time I drive the truck..)
--Simon
Old 06-22-2021, 10:11 PM   #11
Engine: C7 Cat
Hello Simon
I believe your Dodge Laramie is a PAC-BRAKE exhaust brake and not a true engine Jake brake. So why not fit your bus with a PAC Brake system?
Cheers
Oscar1 is online now   Reply With Quote
Old 06-23-2021, 10:22 AM   #12
Simplicity's Avatar
I get that regenerative braking uses the kinetic energy and makes the motor a generator.
And I'm not saying I'm right here, I'm just thinking out loud, that Thelma is still creating heat and resistance. It's they're away to capture that energy for charging the house batteries?
