Old 04-24-2019, 01:58 PM   #101
Coachwork: Thomas Built Buses
Chassis: FS-65
Rated Cap: 66/44
More info from another forum
https://www.steelsoldiers.com/showth...ol-to-C7/page2
Ab01ns is offline   Reply With Quote
Old 04-29-2019, 03:59 PM   #102
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
Originally Posted by Ab01ns View Post
If I had added cruise control to any of our 1078s/1083s in the motor pool I wouldíve probably abused it haha. I hated how stiff the accelerators were on those trucks.
WARGEAR is offline   Reply With Quote
Old 07-29-2019, 10:45 AM   #103
Chassis: FS-65
Rated Cap: 66/44
Switches have been pulled from a donor Fld120 with a 3406E of the same vintage. I will be pulling apart the dash harness today to see if the dash connector is has is the same. Fingers crossed that it is20190728_174033.jpg
Old 07-29-2019, 11:00 AM   #104
Switches have been pulled from a donor Fld120 with a 3406E of the same vintage. I will be pulling apart the dash harness today to see if the dash connector is has is the same. Fingers crossed that it isAttachment 36034
Roll Your Own Build Thread
Old 07-30-2019, 01:20 AM   #105
I for one sure hope it works ... I have a beast wanting cruise.
ECCB, your image did not post.
Old 07-30-2019, 04:44 AM   #106
I was up... hmmm I wonder what the heck.
Old 07-30-2019, 09:28 AM   #107
Chassis: FS-65
Rated Cap: 66/44
No such luck. On the FLD120 the CC wires disappear into the main loom of the harness and reappear at the chassis connector.
I will need to wire them directly into the ecm connector. Next weekend I'll take a stab at it.
Also consider wiring a potentiometer in series with the throttle, attaching a self latching relay to the brake light and just spoofing the throttle signal.
We'll see what I end up doing...
Old 07-30-2019, 10:35 AM   #108
Spoofing the throttle is dangerous self latching relay or not, not because you can’t stop but the computer doesn’t exert as much effort into maintaining RPM as it does for speed on cruise so the result is lots of speed variance as you make even the slightest incline or decline .. the cruise also tells the computer to push the info to the transmission , if it’s a 3060 or 2000 then the throttle modes change when going for cruise vs dead foot driving, with dead foot you’ll reach an eventual point of downshift but not as active as cruise..
Old 07-30-2019, 04:42 PM   #109
Chassis: FS-65
Rated Cap: 66/44
Spoofing the throttle is dangerous self latching relay or not, not because you canít stop but the computer doesnít exert as much effort into maintaining RPM as it does for speed on cruise so the result is lots of speed variance as you make even the slightest incline or decline .. the cruise also tells the computer to push the info to the transmission , if itís a 3060 or 2000 then the throttle modes change when going for cruise vs dead foot driving, with dead foot youíll reach an eventual point of downshift but not as active as cruise..
Cool good to know. I guess I'm pulling the chassis connector off this weekend and having some fun.
On a side note how to I attach the pins into that thing to make a solid connection. Do I need a special cat tool?
Old 07-30-2019, 07:38 PM   #110
CAT may sell the tool, but chances are the connectors were manufactured by someone else.. I think molex made some of them...
you can buy the pins from CAT..
https://parts.cat.com/en/catcorp/ele...inals/133-0969
https://parts.cat.com/en/catcorp/ele...inals/305-5362
general harnesses.. maybe someone can find the CAT part number for the cruise harness. and you may be able to find it?
https://parts.cat.com/en/catcorp/har...tId:undefined&
Old 07-31-2019, 02:25 PM   #111
Chassis: FS-65
Rated Cap: 66/44
I will go buy the pins from cat this Friday then. Thankfully cat is right near the yard where I keep the bus. I will take a look at this wire assemblies too
Old 08-17-2019, 07:42 PM   #112
Chassis: FS-65
Rated Cap: 66/44
Success. Switches are in and it works. I didn't even need the ecm connectors, the wire were already there. I just spliced in and connected up the switches20190817_194121.jpg
Old 08-18-2019, 05:35 AM   #113
That is so cool! You will have to detail the wiring you had to do for it.
Old 08-18-2019, 07:00 AM   #114
Success. Switches are in and it works. I didn't even need the ecm connectors, the wire were already there. I just spliced in and connected up the switchesAttachment 36567
Old 08-18-2019, 08:20 AM   #115
Chassis: FS-65
Rated Cap: 66/44
Oh and I forgot that I had to use cat ET to enable the CC.
If you don't have access to a laptop and j1939 interface, you will have to pony up and pay for an hour of shop time to reprogram literally one parameter. Its the "cruise control low speed"
You disable it on a cat by setting low and high to 127mph. Initially my CC didn't work. I set the low limit to 35mph and that was it.
Old 08-18-2019, 08:25 AM   #116
Chassis: FS-65
Rated Cap: 66/44
I followed this exactly. Used a 4 conductor multi core wire run up through the firewall to the dash and connected to the wires from the switches. I still am amazed how easy this was. Thomas said it couldn't be done. The hardest part was physically getting to the body connector on the ecm. It's really burried.tapatalk_1565912111668.jpg20190814_205906.jpg20190814_205910.jpg
Old 08-18-2019, 09:08 AM   #117
ive been looking to experiment with CAT ET.. where did you get it? mhhauto or some the like?
Old 08-18-2019, 09:18 AM   #118
Chassis: FS-65
Rated Cap: 66/44
The computer belongs to a friend's mechanic who leaves his service truck at the yard and lets me use it when he doesn't need it
I am eventually going to buy a toughbook and a nexiq so I can use it on the road but this works for now and you can't beat the price.
Old 08-19-2019, 01:42 AM   #119
I might have to add this to my list of things to get done right now!
Thank you for the "instructable".
Old 08-19-2019, 02:22 AM   #120
geminusprime's Avatar
Chassis: Vista 3600
Engine: DT466E / AT545
I've got a spare toughbook (or three), will a nexiq work for a International 3600 Vista?
geminusprime is offline   Reply With Quote
