Originally Posted by Ccantine
Hi folks. 2004 International with the T444e and Allison 2000. Used the cruise control for first time. I know on a car you just tap the brakes to disengage, but in the bus I had to really step on the brake to get it to disengage. A bit scary the first time! Is this normal, can it be adjusted, or is this something I should be worried about? Thank you.
if your bus has air brakes, the cruise uses the same switches as the brake lights whiuch are actovated by actual air pressure going into the brake system so it takes a good press to cancel it..
if its hydraulic brakes then there is a bit of pedal travel before it triggers the brake switch
