Details out of the way:
2004 Thomas Saf-T-Liner MVP
CAT C7
Before purchase had a diesel mechanic change oil and oil filter, coolant, and overall get her into running condition. And she ran fine and got me from KY to OK.
I'm going to first go with it probably needs the batteries charged.
Got the bus to it's resting spot in December and then cold weather hit hard and wasn't able to even get to the bus for almost 6 weeks. And of course then wouldn't start. And since then we've had plenty of below freezing days including lots of snow. But now we've had much more consistent warmer weather. So basically I don't know what would be the first steps. I have cleaned off the battery cables and made sure they were back on all snug and happy.
Common things I have read about not starting:
Low Battery
Solenoid for the Starter
Need to crank it longer
Heater grid not working
Fuel injectors / fuel pump issues
I will be going out and checking the battery charge this week. Right now voltmeter is sitting at 12. So hopefully it's as simple as needing a charge. But any other steps y'all think are worth pursuing, I'd love to know.
And side question about jumping. With two batteries would I still connect cables to the - and + terminals that are connecting to the bus, as in the cables that are leaving the battery housing?
Thanks!
