Old 12-22-2019, 10:14 AM   #1
Dump air solenoid?
I recently purchased a 1994 Thomas mostly finished skoolie with an 8.3 Cummins. The attached picture is of a solenoid that is leaking air. It was located under the air filter housing. The identification tag is worn. Anyone know where I can get a replacement and what it might control? I have been browsing this forum for a little bit and it is a wonderful source of knowledge!
oliverbutthead is offline   Reply With Quote
Old 12-28-2019, 09:19 AM   #2
It is likely control solenoid for your fan clutch. But it could control most anything, such as exhaust brake, radiator shutters, etc. Try an auto parts store that has a heavy duty counter. Most likely what you get will look nothing like that. Most places only carry a cheap plastic solenoid. New trucks even have plastic part. All it is, is a N/O or N/C valve, depending how it is plumbed.
Nitro 10 is offline   Reply With Quote
Old 12-28-2019, 05:41 PM   #3
Thanks for the Info! I will take it in and see what NAPA or similar can get..... I haven't followed the air lines yet to see where they go......that would probably help
