Go Back   School Bus Conversion Resources > Skoolie Tech > Mechanical and Drivetrains
Click Here to Login
Old 11-24-2022, 02:35 PM   #1
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
ECM won’t boot, can’t turn in headlights until I check battery volts with multimeter?
Hi all, I have a weird one.
The common circumstances leading up to this issue: laptop running with ungrounded ac adapter plugged into my house inverter, USB nexiq plugged into bus data port and laptop.
The issue: turn the key to ON, dash lights up for maybe a second then goes dark. Transmission touch pad stays on. Obviously can’t start the engine. If turn on the parking lights I hear relays buzzing, turning on headlights kills the shift pad too.
The only fix I’ve found both times this happened: use my analog multimeter to check the battery voltage at the battery box. It usually says 12v. After that I can crank and start no problem.
In the process I checked the main battery ground, unplugged the laptop ac adapter and nexiq, a variety of other things to no avail.
So what the heck is going on? Do I have bad batteries? They’re about a year and a half old.
dbsoundman is offline   Reply With Quote
Old 11-25-2022, 06:31 AM   #2
it almost sounds like bad batteries or a bad connection to one of them. the telltale is the fact the shift pad dies when you turn more stuff on indicating a voltage drop. you can check the voltage at the battery terminals when the key is ON and see if it has dropped.. if it hasnt then I would start checking voltage at various places in the bus..if it has dropped way down then give the batteries a good DEEP charge.. meaning a good quality charger on them overnight..
in a vehicle one time I had a bad ground.. when I tested voltage from a spot in the fuse box to a metal dash support I had 8 volts.. (12 volts acros the battery).. so then I ran a wire =clipped on the battery ground itself to my meter and testd from that to the + point in the fuse box and came back with 12.. fixed the frame ground and the car drove great..
Old 11-25-2022, 06:35 AM   #3
Year: 2006
Chassis: MVP-EF
I was inclined to think battery ground issues too but I did already clean up the main battery ground. There’s various other terminal blocks in between I haven’t fully located yet, it may be time.
I bought the batteries from a local battery store (battery wholesale), maybe I need to have them test the batteries just to make sure I don’t have a dead cell or something? The fact that I’ve been able to resolve the issue by putting a multimeter across the battery terminals made me wonder if there’s a BMS or something else weird in these batteries that’s getting reset by the very high impedance load of the meter?
Old 11-25-2022, 09:55 AM   #4
Chassis: International 1753
Engine: 6.9 International
I'm not a fan of analog multimeters, unless they're pretty accurate. A cheap dvom is much more accurate then most analog multimeters.
Like Christopher, I believe your batteries are just that low, and your multimeter isn't telling you correctly. At least that's what your symptoms sound like.
You can check grounds and powers by doing a voltage drop test. It gives you a much more realistic picture then an ohm reading. There are plenty of videos on youtube that describe the hows and whys of it.
I don't know how you putting a multimeter across the batteries change anything, unless the terminals are loose and touching the batteries with the meter disturbed them enough to get a better connection.
Old 11-25-2022, 03:04 PM   #5
and ive seen that happen!
Old 11-25-2022, 03:40 PM   #6
Year: 2006
Chassis: MVP-EF
I had a perfect start today, drove maybe 10 miles, stopped for fuel…just got relays buzzing when I turned key to on. Tried the multimeter trick, didn’t work. Made sure all my accessories were unplugged/turned off, tightened all the battery connections just a tiny bit…fired up.
My frame is rusty around the grounding points, I think when I get home I need to disconnect those grounds, hit the metal with a flap wheel until it’s shiny, reconnect and torque, then throw some paint over it for a little extra protection.
Old 11-28-2022, 07:17 AM   #7
That sounds exactly like sporadic contact then. Sound like you have a good plan of attack. If that doesn't work, check for voltage drop across the various connections while trying to crank.
Old 11-28-2022, 08:47 AM   #8
Engine: DT466e 215hp Allison 2500
Check the starter connections are tight while your at it, that's where I found the mystery problem on my bus. Space is tight in the area so best disconnect the battery beforehand.
Timeline is offline   Reply With Quote
