Fan Motor
Hi everybody!
I found the part number on the radiator fan motor in my 1994 WestCoastER CAT 3116 powered rear pusher.
It’s a Haldex 1820025
I called a Thomas dealer near me.
They said that part was unavailable , but y they had some in stock in Memphis. Only want $1500.00 for it.
Hmmm…
I’m thinking that’sa bit much.
I’m looking at pulling the motor and associated hydraulics.
Anyone on here done something similar?
It’s a passenger side radiator.
Plenty of room after I take the pump and fan assembly off for a new electric fan setup.
I’ve done this plenty of times for custom engine installs in regular gasser vehicles with a front mounted radiator.
Never anything like this…
Some googling says I need about 3400cfm. That’s fairly easy to do with electric fans.
A brand new fan setup with a new controller looks to run about $250-$400 , depending on what exactly I need.
Much better than $1500 plus!
Just got to figure out if I can just plug the fan port on the power steering pump. It “looks” like an independent output, separate from the power steering lines.
Thanks for reading!
