Old 09-15-2024, 01:42 PM   #1
Year: ‘09
Chassis: Vision
Engine: 6.7
Rated Cap: 35’
Fuel Issue
2008 BBV with 6.7 Cummins. Changed the spin on fuel filter, but did not add fuel to the filter prior to installation per the manual. Can't get the engine to fire up. A little help please.
Ranchorossa is offline   Reply With Quote
Old 09-15-2024, 02:16 PM   #2
Coachwork: Busless for now
You lost prime. Take the filter off and fill with fuel. There may be a push-button on the filter adapter. If so, pump it with your finger until you feel resistance.
Good luck.
Kentucky Dreaming is offline   Reply With Quote
Old 09-15-2024, 03:09 PM   #3
Year: ‘09
Chassis: Vision
Engine: 6.7
Rated Cap: 35’
I normally fill the filter with fuel, but the manual said don't do it. Don't follow the manuals. I got it going, thanks.
Old 09-15-2024, 03:46 PM   #4
Glad you are rolling again!!!!
Always fill the lines when you open the fuel system.
Old 09-21-2024, 04:16 PM   #5
Good luck.
Yeah that, you should be able to use the thumb pump to prime it but pulling the filter off again would be faster by at least a couple of hours and save your thumbs for better things like holding your beer bottle. I WILL NEVER HAND PUMP AGAIN.
shorthair is offline   Reply With Quote
Old 09-21-2024, 04:22 PM   #6
nikitis's Avatar
Rated Cap: 29
If there's that much fuel in the filter when you remove it, it should be that much when you re-insert it imo.
nikitis is online now   Reply With Quote
Old 09-22-2024, 08:56 PM   #7
sportyrick's Avatar
Chassis: F33695
could be the manual is concerned about the quality of fuel you would be putting into the filter, remember the fuel in the middle of the filter is already past the filter stage and could compromise your injectors, priming with pump guarantees all fuel is filtered
Old 09-24-2024, 08:56 PM   #8
Engine: T444E, Allison 2000
Yup. Common rail injectors will get angry very fast with poor fuel.
I use a little plastic plug that comes in all sizes for caping lines and shove it in the center hole. Fill fuel filters from the outside of the center hole.
If I can prime an engine either hand or electric I try too first. If time is not on my side I pre-fill. Depends on the situation.
Omnibot2000 is offline   Reply With Quote
Old 09-24-2024, 10:12 PM   #9
Not only do they get upset but when they throw a tantrum it gets real dang expensive, both in injectors and injector pumps cause fuel is their main lubricant. Lack of fuel can easily toast both in just a couple of minutes of cranking, so caution is advised.
Old 09-24-2024, 10:32 PM   #10
Agreed as well
I've seen more times than I care on the lack of fuel. Same person twice had trouble starting a Ford 6.4 powerstroke. Cranking till batteries go dead. Charges them up and cranks some more. When it does fire up he screamed the engine to red line thinking it will purge air.
Told the person twice, key on and off to cycle the electric pump to purge air out. Then start and allow to idle. I remember keying on/off 6 times and starts every time on first crank. Then allowed to idle for 5 minutes.
Him, got low fuel pressure codes both times in a week. Fuel system damage.
Old 09-25-2024, 01:15 AM   #11
Agreed as well
Both my dad and grandpa were firm believers that all knowledge had a price tag attached some had $ signs others were just plain painful and if you were too stupid to learn the first time around it was no one's fault but yours.
