Old 12-08-2022, 01:04 AM   #1
1catlady's Avatar
Chassis: Allison
Engine: 3800 466e international
Rated Cap: 35
Gmc savana 3500 short bus security lockout
So my 1999 savana 3500, with a vortex 350 has a pass lock issue. I can't seem to bypass it so I'm going to replace it. Anything I should know about this. Any one had any experience with gmc pass lock 2?
I do what I want, 1catlady
1catlady is offline   Reply With Quote
Old 12-08-2022, 02:44 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
what bus body so someone can be more specific.
Old 12-09-2022, 07:46 AM   #3
1catlady's Avatar
Chassis: Allison
Rated Cap: 35
Bluebird microbird 4 window
Old 12-09-2022, 08:41 AM   #4
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
I want to think you can bypass this with a resistor of a specific value that makes it think the correct key is in the ignition switch. You take an ohmmeter and read the value of the chip in the key, and then at the bottom of the steering column is an orange cable that contains two wires, you cut the cable open and solder a resistor the same value as the key between those two wires.
This "might" be a cheap fix to your issue. Will not cost much to try it.
PorchDog is offline   Reply With Quote
Old 12-09-2022, 09:46 AM   #5
Take a look on Utube for GM passlock 2. Here is a starting point:
#security lock out
