Hi guys, reaching out for some direction on troubleshooting this issue I got: Bus has been sitting all summer while i did a roof raise. Finally took it out and it runs great but it tops out in the 25mph range in 3rd gear i think at about 1700rpm. The speedo is obviously off because at slow speed(~15mph) it reads 45mph and when the engine starts cutting out power the speedo reads 65mph but the actual speed is prob 25mph. My governor is set to 65mph so I'm guessing it is cutting out due to the faulty speed reading. I drove it down the road about a mile, put about 20gal of diesel in it, and then drove it back home. It accelerated good until it reached "65mph" on the dash then stayed at that speed.
Anyone have thoughts on what I should troubleshoot? I have decent mechanical ability but need direction sometimes, lol. I'm definitely going to pull the gauges and check the solder joints but not sure if I should be looking at the speedo pickup on the trans or...?
**I held off posting this until i could drive it again. When I took it back out it drove fine and the speedo seemed accurate. I drove it about 15 miles and everything was good like when I drove it 200 miles home. So I guess it is an intermittent problem which I recall the mechanic for the previous owner mentioned it had intermittent gauge issues. Havent looked at the dash yet.
