Originally Posted by lcm0027
It’s a 2ga wire going to a believe the grid heater. 200something amps runs threw it. I don’t believe the connection can be repaired. I think I have to replace this whole component?
Check the solenoid for heat damage at the terminal, you might get away with just repairing the wire. You can get a solenoid switch rated at the correct amperage aftermarket and save money if it needs to be replaced, there's nothing too terribly special about them.
