a different chassis vehicle is definiterly an option... Bus bodies are assembled completely before they are married to the chassis... so in effect they are simply setting on the frame and attached with body clips.. so removing a bus body and setting on another frame is definitely viable..
I think the first stage is determining how you want tio power it.. ie like you mention, electric? diesel? gas? and do you want it highway capable in terms of speed and torque? towing a boat? just a cool bus to take to Car shows and cruise your friends in? (thats what all 3 of my busses are for)..
as far as whats possible and whats not.. i know for sure the Bluebird pictured above was built.. someone on one of my classic bus forums has seen it.. its powered by an SV392 from what I understand..
the first one was a movie prop bus but was fully operational.. you can read about it.. its a Bus from the sequel to the movie Dumb and Dumber.. it had a beefed up engine / suspension and such so it could be used in stunts.. I have no idea its whereabouts now.. or if they destroyed it in the movie...
those 2 should tell all the nay sayers here that what the OP wants can be done..
The Canadian Campground inquiry ended up going nowhere.
I was thinking diesel (I'd like an 8.3L Cummins), but open to gas if need be. Budget wise (including bus acquisition), I'm willing to go up $20K, possibly $25K if that means I get everything I want.
I'm set on only having two windows and want the bus that short. So it appears the drive-train will be the biggest issue.
In regards to goals (in order of importance):
1.) Everyday driver. I want to use this as my everyday driver, not just an occasional joyride or yard ornament. So it'd need to be engineered accordingly.
2.) Performance. I want to REALLY get up and go in this thing. I'd imagine that would kind of take care of itself if I got something like a full size bus with 8.3L Cummins and shortened it down to the aforementioned size.
3.) Fuel Mileage. Not most important thing, but would be nice to get some decent mileage as my everyday driver.
