Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 04-30-2020, 01:09 PM   #1
Gorzie's Avatar
Coachwork: Bluebird International
Engine: T444e
Rated Cap: 35
Help needed identifying gaskets
Hello all,
I have a 1997 T444E
I need to replace my water pump gasket (maybe the water pump and thermostat too since I will have it off) . I figured I might as well replace the oil cooler o rings since it looks like they might be starting to leak. There is also a little oil leak that comes from the passenger side I think from the HPOP resivore. I found gasket/seal kit but there are a few items I have no idea what they are for. I am sure someone here knows what the circled items are for.
I recognize the water pump gasket and the oil cooler orings and gaskets. I think I even know the oil resivore gasket (circled in blue).
If you have any suggestions on other preventive things to check/replace while the water pump is off please let me know. I don't know to get stuck on the side of the road somewhere.
Thanks in advance for helpful comments.
Michael G.
1997 Bluebird IH 3800 6 window T444e
https://www.skoolie.net/forums/f11/m...ird-28058.html
Gorzie is offline   Reply With Quote
Old 05-04-2020, 11:36 AM   #2
Chassis: International 1753
Engine: 6.9 International
I'll try and help.
What's the PN for the kit?
The oil cooler O-rings are the 6 in the bottom left corner. The back end housing to block gasket is above and to the right of your red circle, with the front housing gasket between the orange and green circle.
The green circle looks to be front and rear main seals and gaskets.
Blue and orange circle I believe is for the timing cover and hpop.
Not sure what the red is.
Old 05-04-2020, 12:27 PM   #3
Gorzie's Avatar
Engine: T444e
Rated Cap: 35
Thanks.
Here is the url for the kit
https://www.agkits.com/navistar-7-3l...B#.XrBCDt9Ok0M
Michael G.
