Old 04-30-2021, 08:29 PM   #1
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
How do I adjust this pressure switch?
I bought a VDO 8-13 psi adjustable pressure switch that is factory set at 10psi.
I went to adjust the psi and thought it would be a simple matter of using a small flat or Philips head screw driver. It has a rubber grommet that appeared to have a slit in it, but when I went to push the screwdriver in, it was solid.
I pried out grommet hoping to find the adjustment screw under it. No such luck.
I tried searching online, on the manufacture's website and no luck.
Can anyone tell me if these switches have a common way to adjust the psi??
Thanks!
Steve
Old 04-30-2021, 09:08 PM   #2
Shamoke's Avatar
Engine: Cummins 5.9L 24 valve
Thanks!
I'm no expert but that looks like a pressure sending unit and if it is then it'
s not going to be adjustable. It just closes an internal electrical contact at a certain pressure range, in your case 8 to 13 psi. What is it for?
Shamoke is offline   Reply With Quote
Old 04-30-2021, 09:36 PM   #3
Simplicity's Avatar
It's not a pressure sending unit, it's a pressure switch.
Why would it say it's "adjustable" between 8 and 13 psi if it we not truly adjustable?
I added a Tee to my MAP sensor port and use the switch to activate my transmission modulator for shifting under load.
It works at the factory 10psi, but I want to test it at the lower psi level.
Steve
Old 04-30-2021, 09:41 PM   #4
s2mikon's Avatar
Engine: Cummins 8.3
These are the ones I used. http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
s2mikon is offline   Reply With Quote
Old 04-30-2021, 09:42 PM   #5
s2mikon's Avatar
Engine: Cummins 8.3
They also have them on evil-bay too.
Old 04-30-2021, 09:43 PM   #6
s2mikon's Avatar
Engine: Cummins 8.3
Did you look down the threaded hole for a screw?
Old 04-30-2021, 10:37 PM   #7
Simplicity's Avatar
Figured it out. It's adjustable, but not with a typical screw head. You use an allen wrench. Would have been so simple if they could just put that in the packaging, right?
Thanks for the replies!
adjust, pressure switch
