03-08-2020, 01:05 PM
Hub Oil Question
I've never seen anything like this. My hub oil is a greenish gray with dark green spots in it.
Planning on changing it today but wanted to know if anyone ever saw any like this or knows what's up.
03-08-2020, 10:39 PM
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Maybe got some moisture in it?
Ted
03-09-2020, 12:03 AM
Right, that looks like the sort of green slime you see around the edges of the docks and such.
03-09-2020, 09:05 AM
MMJ tincture?
Don, Mary and Spooky the cat.
03-09-2020, 09:08 AM
Originally Posted by 2kool4skool
MMJ tincture?
Just had some, thanks!
03-09-2020, 10:57 AM
Chassis: International 1753
Engine: 6.9 International
Definitely looks to have had water present.
I'd drain, and flush with a solvent, then refill with clean oil.
Maybe make sure the bearing aren't trashed by seeing if the end play is in spec.
03-09-2020, 11:00 AM
thats the plan. had to go get my bottle jack from my 'bus yard".
03-09-2020, 02:31 PM
Put a little of the green stuff on a white paper towel and let it dry out in the sun. If it is biologic, it should die and change color.
03-09-2020, 04:48 PM
Its almost surely water contamination. Smells strongly of gear oil.
I picked up some 80w90 at tractor supply. I'll change the oil tomorrow.
03-09-2020, 10:30 PM
Now I feel guilty for not checking mine...
03-09-2020, 11:46 PM
So how high are they supposed to be filled?
Pull the rubber stopper off and the oil is supposed to be right at or slightly below the rim?
03-10-2020, 01:00 AM
Chassis: IH
Not that much. About halfway from "empty" to the bottom of the hole. Some covers have a pair of "lines" (circles), the outer denoting "minimum" and the inner reflecting "full".
03-10-2020, 01:54 AM
Thank you, I may be checking into that soon.
03-10-2020, 06:14 AM
There's a line. Bout a quarter inch from the plug.
03-13-2020, 12:18 PM
I drained it out and refilled with some cheap gear oil. Spun the wheel for a bit then drained and refilled it.
The drivers side oil looks new it was just the passenger side. The drain plug has a magnet in the end and it did have a bit of metalic debris stuck to it. Nothing large, but not very reassuring. I pried on it a bit with a bar and can't feel any noticeable play in the bearings.
Gonna monitor this and think about getting the bearing on that side replaced.
03-13-2020, 04:30 PM
Chassis: IH3800
Uh, all my tinctures and feco are quite a bit darker, but most of what i grow is heavy with anthocyanins so I guess you could get some looking like that, maybe acupulco gold tinct? Good to know other skoolie peeps use God's medicine too!!
03-13-2020, 09:14 PM
Since my hubs came spray-painted I don't have any lines to see...
Filled up is how far below the bottom edge of the plug?
One of mine looks like spraypaint may have got inside!
03-13-2020, 10:12 PM
EVERY day, man!
03-13-2020, 10:13 PM
bout a quarter inch from the bottom of the plug.
03-13-2020, 10:40 PM
Thanks! Mine should be topped up!
