Old 12-22-2021, 12:20 PM   #1
olivemartini's Avatar
Year: 2006
IC wonít start
HALP
Iíve jumped it, used diesel additive for gelled fuel, added winter diesel, fluid levels are good, emergency latches are good, reset codes which didnít work, ???????????????
https://youtube.com/shorts/ydXgXUoOTss?feature=share
https://youtu.be/veCQ7ndfag8
https://youtu.be/xOf5JaUGe6U
https://youtu.be/HFA0XZ5Vswg
olivemartini is offline   Reply With Quote
Old 12-22-2021, 12:40 PM   #2
ewo1's Avatar
Originally Posted by olivemartini View Post
HALP
Donít take this the wrong way but some of us donít have time to watch 5 videos.
How about a plain Jane explanation of what is going on!
Old 12-22-2021, 12:48 PM   #3
Year: 2006
No worries!
It’s trying to turn over but won’t, the engine is making a kind of clicking sound, codes ol-95 and d1 14 12, both of which say oil level sensor failure. Battery drains pretty quickly, even when it’s hooked up to my jeep (for two hours).
Old 12-22-2021, 01:01 PM   #4
ewo1's Avatar
No worries!
Itís trying to turn over but wonít, the engine is making a kind of clicking sound, codes ol-95 and d1 14 12, both of which say oil level sensor failure. Battery drains pretty quickly, even when itís hooked up to my jeep (for two hours).
Clicking sounds and batteries that drainÖ.
One thing at a time, put fresh batteries and make sure your battery terminals/ connections are clean and tight.
Those codes donít seem right but you can expect that with low voltage/ current.
If it starts with fresh batteries you can then check your charging system.
Old 12-22-2021, 01:36 PM   #5
Coachwork: IC
Chassis: CE200
Engine: T444e
Rated Cap: 27,500
I have a 2004 IC CE-200 with a T444e. Twice this summer it turned over but wouldn't start. Both times it turned out to be low battery voltage. As soon as I got the batteries fully charged it fired right up.
Given that you're in MN I expect that fully charged batteries are even more critical, don't underestimate it.
In case it's not a simple battery issue, International publishes a hard start/no start diagnostics manual. I have the one for the T444e, I got the manual number out of the engine shop service manual's forward. It's detailed, definitive and easy to understand, you should try to locate it for your DT466.
Good luck with it.
Oldyeller is offline   Reply With Quote
