08-01-2020, 07:59 PM
Chassis: FE300
Rated Cap: 53
Idle Time Question
We're looking at a bus here in Louisiana. It's a 2001 Thomas Safetliner with the 8.2 Cummins engine. It only has 27,000 miles but has idled for 13,000 hours running the A/C. Is that anything to be worried about? What would that equate to in miles?
Thanks!
08-01-2020, 08:43 PM
Chassis: IH
Cummins did not make an 8.2, it's likely an 8.3 and there's a typo. 27K miles sounds questionable, since it's pretty common to replace the dash in these when the gauges quit working. The hours, on the other hand, sounds within range for the age. My bus has somewhere around 212K miles and over 10K hours, but likely didn't get much idle time other than usual school bus route service.
More important than the miles or hours is condition and maintenance. How was it treated and cared for during its life? Has the engine been rebuilt at some point? Are service records available?
08-01-2020, 09:33 PM
Chassis: FE300
Rated Cap: 53
No service records, the guy who has it swears the mileage is correct and that it was a Vegas bus that idled a bunch. Your deductions sound more plausible to me though.
08-01-2020, 11:06 PM
Coachwork: Thomas 4-Window
Chassis: 2003 Ford E350
Rated Cap: 6
I'm going with Brad on this one... At 27,000 miles, it might still be sitting on the original tires!
Look underneath. If it's only got 27,000 miles on a Vegas bus, that bottom side should be immaculate.
08-02-2020, 01:06 PM
Engine: 3126b 210hp
Rated Cap: 48
Clark county busses are usually low ceiling. I visit in-laws out there and that’s what I see. Does the roof drop down after the drivers seat?
[emoji3522]
08-02-2020, 02:31 PM
Chassis: IH
At 2001 year model, it probably has an engine computer. You *ABSOLUTELY SHOULD* have some independent mechanic plug into it to check for active/recent fault codes - the dash may or may not be correct on the mileage but the computer absolutely should be (unless by some rare chance it was changed too). At that point you'll either have confirmation of the miles or (more likely, in my mind) a good haggling point on the price.
While he's at it, he should be able to set/reset the cruise (if equipped, which it should be), the governed top speed (if set) and the idle timeout (if enabled), along with anything else that can be changed. He won't, however, be able to give any more top speed that is limited by max RPM and gearing.
08-02-2020, 06:19 PM
generally alot of idle hours isnt the greatest.. however idling in a hot climate is better for that engine than in cold weather.. if you have someone read the computer, have them check for tattletales.. all that hot weather you want to make sure the computer hasnt show repeated over-heat conditions..
08-03-2020, 07:49 AM
Chassis: FE300
Rated Cap: 53
Thanks for all the information guys. Reading more about idle time, and with you guy's input, we decided to pass on this one. Just too many unknowns to drop $10k on. The hunt continues.
08-03-2020, 08:07 AM
for 10k you want less than 10k hours, less than 250k miles.
08-03-2020, 04:32 PM
Chassis: FE300
Rated Cap: 53
[emoji3522]
Maybe, it's hard to tell from the pictures. There isn't one from straight on from the side.
08-03-2020, 04:44 PM
thats a low ceiling.
08-03-2020, 05:15 PM
Chassis: FE300
Rated Cap: 53
Thanks, I'll have to watch for that in my hunt.
08-04-2020, 08:54 AM
Engine: 3126b 210hp
Rated Cap: 48
It fits the profile of a Vegas bus so the seller could be right about that part. I’m from N.O. I’ll be bringing my bus to BR for football games if we have em this year. I’m not painting my bus purple but....Geaux Tigas!
08-04-2020, 09:45 AM
Chassis: FE300
Rated Cap: 53
LOL, why not? Every tailgate bus is purple.
08-08-2020, 06:57 PM
Do a compression check. Ditto a leakdown. Then take an oil sample and send it to Blackstone, or another of the oil analysis outfit. Easy peasy! Pay for a PMI by a reputable outfit because they'll tell you what it needs to be legally on the road. And it's really worth forking over for professional to perform a prebuy inspection . . . happily pay for his time. Believe me, doing it before you hand over the dough is when you want to do this (and note; it's absolutely the wrong time to be a piker by beating him down on his fee). Kind of like the old saw, marry in haste repent at your leisure. Same holds with this.
