Old 01-26-2024, 02:09 PM   #1
Is this a starter issue?
Hello!
After years of starting with no problem, by 1999 Thomas full size is suddenly not starting. The only problem I've had with this before has been with the battery, and I know that's not the problem, and I also put fresh gas in.
Also it has been a very mild and wet winter here on southern Vancouver Island, and the bus hasn't been driven since the summer (it has been started semi-regularly, though perhaps not as regularly as it should have been. oops) so that could be a factor.
After reading threads about bad starters, it sounds to me like it could be the flywheel spinning and the solenoid not engaging, but I'm really not sure.
This is a recording of what it sounds like when I try to start it up.
https://www.dropbox.com/scl/fi/p42o1...x8hv5htki&dl=0
My questions are 1) is the starter the most likely culprit? and therefore the next step is tapping on the starter while turning the key? and 2) if so, how hard does one "tap" the starter? Am I risking damaging it if I hit it too hard? Do you tap the starter motor or the solenoid? both?
any advice very much appreciated!
Erin F is offline   Reply With Quote
Old 01-26-2024, 07:15 PM   #2
sportyrick's Avatar
Chassis: F33695
Sounds like the bendix, that's the one way clutch with the starter gear attached to it which in-gauges with the flywheel ring gear. You will have to get your starter rebuilt or grab a new one. There might be a local shop that rebuilds starters and alternators so look in your yellow pages or of course your marketplace to find one. The would be cheaper than the auto parts stores in my opinion, next price wise would be an auto parts store then the stealers.
Old 01-27-2024, 09:40 AM   #3
Engine: DT 466 Mech. Spicer 5 speed
Rated Cap: 34
I agree with SportyRick-- starter Bendix. The Bendix is what pushes the starter gear out of the starter to engage the flywheel. I would think a "starter repair shop" could replace just the bendix.
PorchDog is offline   Reply With Quote
solenoid, starter, thomas
