Originally Posted by TheHubbardBus
Understood, Marc. Thank you. The push-on fittings I was referencing (more accurately push-to-connect, I had the terminology wrong) are DOT-approved for use in air brake applications. That's what I'm replacing.
Sorry, was thinking of the other push on stuff. If they are DOT approved for air brakes, then go for it.
I'm impressed with the technology that's gone into connectors. SharkBite, P-T-C, etc. Used to be you used to have a torch and solder, or special crimping tools for each size, etc. Now, you just push the tube in and you're done.
