So ill be pulling my radiator and intercooler soon and while its torn apart, ill be replacing waterpump, torn belts, timing cover gasket, etc..
So my hoses from transmission/radiator heat exchanger are leaking and im going to drain the fluids/ replace filter and have new hoses made.
Firstly i have a cummins 24v 5.9 with a MD3060. Current fluid is dexron III. I have 141k on the drivetrain now. Its a short 28fter that weighs 17,500lb with full fuel tank. Hard to estimate what my finished build will be, but im expecting between 5-10k more payload (dirtbikes, 125gallons of water, additional 60 gallons of fuel, etc). I also plan to flat tow a 5000lb jeep when i'm done.
That said, i drove 2000 miles and up two steep mountain grades (Guadalupe Pass) and the engine temp and transmission temp never moved off 186. The ambient temps the whole time were between 30-50 the whole trip, and i wasn't running the air conditioner compressor.
So im looking for feedback on those with this transmission as if any of you have or havent added an additional cooler. Im thinking that with the lockup torque converter, that it doesn't have the same heating issues that the AT545 has.
If i were to add one, I would keep the current heat exchanger in the loop, but add a derale thermostat
https://derale.com/product-footer/fl...unt-kit-detail
And i was looking at the below oil cooler.
https://derale.com/product-footer/fl...t/13870-detail
I have room in front of my intercooler, but not sure if its worth impeding the flow, or try to mount it down by my air intake or somewhere by the steps (not oriented toward the wind).
Can anyone help my budget with advice? Should i spend $500 more dollars to add this, or wait until i drive it a bit and add it if i don't like the heat?
Should i spend the extra money to switch my fluid from dexron III to Transynd to handle more heat instead? The dexron III i found is at Tractor Supply. Has anyone used this? Im hesitant since GM stopped licensing the name. The RV forums are all about that Transynd.
https://www.tractorsupply.com/tsc/pr...l?cm_vc=-10005
I need 5 gallons for a drain and refill (and might need a bit more since im changing hoses) so 5 gallon of transynd is about $200 and 6 gallons of Dex 3 is $120.
