Old 03-31-2023, 11:19 AM   #21
congrats on your new Bus!!
use circle-D thats overdrive .. you were probably running against the rev limiter in 4th gear.. circle-D should give you 5th gear which will get your top speed up a bit
Thank you! I just used overdrive going to my friend's house and it drove at 55 like a dream. Even smoother than the regular drive gear. It did use a little bit more diesel but for short distances and the smoothness I get, it's worth it!
sigreddasparks is offline   Reply With Quote
