Old 04-12-2020, 09:50 AM   #1
Exclamation MVP EF manuals?
Does anyone have manuals for a Thomas MVP EF? 2001 model in specific. I have manuals for ER but it would be nice to have anything for the EF.
chinook773 is offline   Reply With Quote
Old 02-10-2021, 05:14 PM   #2
stlthe's Avatar
Chassis: Saf-T-Liner MVP EF
Engine: Cat C7
Rated Cap: 29 (Perimeter Seating)
i agree, i'm going to calll Thomas and see if they can help me out.
in the past they have been very forthcoming (never a 'no') but i havent asked this yet.
I'll keep all informed
evan
stlthe is offline   Reply With Quote
Old 01-16-2023, 07:35 PM   #3
Were you able to find out how to get the manuals, I have a 2002 Thomas MVP-EF (engine front) and haven’t been able to find any.
Scottie O is offline   Reply With Quote
Old 01-16-2023, 11:32 PM   #4
Truthseeker4449's Avatar
Chassis: MVP ER
Engine: CAT 3126
Find and Contact your local Thomas Dealer with your VIN number.
Obtaining the exact manuals can be a bit problematic with these 20 year old buses as Thomas has now put them onto a Daimler portal, however you need to get a login and a warranty status verification to gain access to the portal. I've attempted contacting Thomas directly without much luck, the best they can do for me is give me the part number for the manual. A local dealer likely has a relevant digital copy or two stashed away.
Truthseeker4449 is offline   Reply With Quote
Old 01-17-2023, 09:35 AM   #5
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
I've mostly focused on electrical diagrams, the mechanical elements are more or less covered by Caterpillar documentation or Allison documentation.
https://cloud.tastefordanger.xyz/ind...TbJPSGLfFjwYZ9. These cover both Cat C7 and Cummins ISB engine options. I think the Allison 2000 and Allison 3000 are also covered in there.
https://cloud.tastefordanger.xyz/ind...TbJPSGLfFjwYZ9. Says 3126, but also applies to the C7.
I have more manuals specific to the C7 if you're interested.
dbsoundman is offline   Reply With Quote
Old 01-26-2023, 06:53 PM   #6
Thanks, the engine I have is 5.9L 24 VALVE CUMMINS ISB. I’m looking for a part and part number for a repair.
Old 01-26-2023, 06:53 PM   #7
Thank you, I’ll give that a try.
.pdf, maintenance, manual, mvp, thomas
