Old 01-09-2020, 11:40 AM   #1
Not a bus question. Needs some truck advice.
Hey Everyone,
This is not bus related but since the smartest people that I know hang out here I thought I would give it a shot.
My truck has the 5.9 Cummins, NV-5600 and 3.73 years. I've about had it with the gearing so I stopped by every shop in town and found one that is willing to swap out my 3.73's for 4..11's or 4.33's. Cool!....… Then I got the quote.... Almost $2500.…. That seems awfully high to me. I expected around half of that.
Am I expecting too much for my $$? Or is the shop charging too much?
Thanks.
Old 01-09-2020, 11:55 AM   #2
Chassis: IH
A quick Google search leads me to think this is not a simple carrier assembly swap, and further reading (I'm guessing it's a Dana Model 70?) indicates gears numerically higher than 4.10 require an axle housing swap. So they may simply be swapping the whole rear-end. I wouldn't be surprised if they are quoting a rebuilt axle (about the same cost as getting a rebuilt truck/bus axle).
Old 01-09-2020, 09:06 PM   #3
Chassis: Blue Bird
Engine: ISC 8.3
My 1999 Ram factory service manual happened to be lying open on the table tonight, so I looked through the section on the rear axles. Of course this Chrysler manual does not refer to the axles by their common Dana numbers, but maybe the information is still useful. It says the 248 axle might be equipped with a 3.55 or 4.10 ratio, while the 267 and 286 axles might be equipped with 3.54 or 4.10 ratios.
I guess that supports the idea that if you want a ratio numerically higher than 4.10 then you might (?) have to switch to a different (non-Chrysler) Dana housing.
FWIW, my '98 has the 5.9 CTD and 4-speed 48RE automatic turning 4.10 axles. When I do tow something it's usually heavy and the truck does okay, I guess -- but most of the time I'm running empty and lamenting the 13 MPG fuel economy which I blame on the 4.10's.
Old 01-09-2020, 10:42 PM   #4
Chassis: IH
I have the opposite problem, I'm geared way too low (5.3. However, I have the N175 axle and I want to go to something 3.91 or numerically lower since I want reduced RPM at cruising speed.
Old 01-10-2020, 03:03 AM   #5
I am pretty sure that I have AAM 11.5 axles.
Anyone familiar with AAM and available gear ratios?
Old 01-10-2020, 03:57 AM   #6
Chassis: IH
What is the basis for your conclusion? You didn't mention what axle you had, so I Googled NV-5600 and read that transmission was used in certain years of Dodge trucks 2500 and 3500, and sort of guess-searched from there (not knowing what year or model your Ram was).
Old 01-10-2020, 03:59 AM   #7
I have AAM axles and 3.73 gears. Sorry, I thought that I had already posted that.
I am not sure what "conclusion" you are asking about?
Old 01-10-2020, 05:42 AM   #8
I have the same truck. It is a Dana 80. If you look around the pinion you will see an 80 cast into the housing. The AAM wasn’t used until 03-04. I have been through mine twice. I think if you step up to 4.10 you will need to change the carrier that the ring gear is mounted on. The bearings in mine were pretty worn at around 200k and ended up spinning on the carrier and had to be replaced.
Trailer2 is offline   Reply With Quote
Old 01-10-2020, 07:24 AM   #9
I am fairly certain that my '04 has AAM axles.
I am beginning to get the idea that the swap is a bigger project than I thought it would be. Perhaps the $2500 is not out of line.
