Originally Posted by Tsmith
Which one works?
I purchased a nexus on amazon and it didn’t seem to work. Said no codes when the CEL on the dash is clearly on.
you need a J1708 / J1939 reader.. the protocol is not OBD2 unless the bus is a van cutaway then they run on OBD2..
if you have a smart-phone or tablet then the Bluefire is a good device of choice that many use..
you can get it in the 6 pin round or 9 pin round connector depending on what the conector under your dashboard is..
