Old 03-13-2020, 09:27 PM   #1
PCV oil catch can question.
On my 3126 turbo CAT I've got this wee bit if IHC technology...
It's hooked up to where the PCV on the valve cover would go and the bottom of the can plumbs into the oil pan.
So I opened it up today -- it contains a fancy micro-mesh filter. And I drained out the can (before I realized it's probably self draining) which didn't have more than a couple tablespoons of oil in it.
The filter had a build date of 2013. Is there any routine maintenance required for this?
Since it's not part of the standard CAT 3126 it's not covered in my manual.
David
The Murder Bus
Old 03-13-2020, 10:15 PM   #2
Attachment 42194
Probably catches the "slobber"?
Just keep it emptied would be my guess. But that's all it is lol.
Old 03-14-2020, 02:58 AM   #3
Could be a slobber catcher... the slobber tube usually drops straight down from the valve cover.
Old 03-14-2020, 09:11 AM   #4
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
emission laws required the oil laden crankcase fumes to no longer be vented directly to the atmosphere
mmoore6856 is offline   Reply With Quote
Old 03-14-2020, 09:13 AM   #5
mmoore6856's Avatar
Chassis: chevy
maintenance requires only cleaning the filter it is self draining as you figured out
Old 03-14-2020, 09:29 AM   #6
____Thanks!
David
The Murder Bus
