Old 03-27-2021, 10:07 AM   #1
Primary Braking Failure
04 Thomas Saf-T liner C7.
No problems driving/operating. Parked it for 6 months for conversion. Started it up. Brake pedal is floppy, no pressure. Parking brakes work. I've tried bleeding the air system, restarting the bus. Air pressure system works but the main brake pedal is floppy and no pressure.
Help.
Derka is offline   Reply With Quote
Old 03-27-2021, 02:34 PM   #2
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
I'm guessing you need a new treadle valve.
Look at the Sky; look at the River. Isn't it Good?
Old 03-27-2021, 10:30 PM   #3
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
If you have equal air pressure in your tanks and the emergency air brake is working, then you just have to isolate the main pedal portion of the system.
This video may help.
Steve
Old 03-27-2021, 10:48 PM   #4
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
Interesting video thanks. Seems like a blockage or valve. Ice?
Rwnielsen is offline   Reply With Quote
Old 03-27-2021, 11:06 PM   #5
Simplicity's Avatar
Another good video about air brake relays.
Steve
Old 03-28-2021, 11:44 AM   #6
I really appreciate everyone who posted.
This just in.
https://photos.app.goo.gl/nqQQubgVYqvZUQrv6
https://photos.app.goo.gl/zDEJ6iVgHNHwiLT3A
It looks like the steering column but the steering works. What is this fluid leaking?
Old 03-28-2021, 12:06 PM   #7
Simplicity's Avatar
When I'm in these situations, I clean off the parts, take close up pictures of any identifying markings, research it to discover what it does, how it works and any known issues.
Others may be able to look at it and identify it off the top of their heads, but I don't know what those are.
If the one with all the bolts in the picture that's got some thin liquid coating, I'm wondering if there's some kind of a hybrid hydraulic / air mechanism on your bus. If so, maybe that's hydraulic fluid, you have a leak and there's not enough pressure to activate your air system????
Steve
Old 03-28-2021, 12:53 PM   #8
Rated Cap: 26 foot
It helps when you attach the pics instead of requiring a log-in to view them. Can't help, not logging in. Sorry.
Old 03-29-2021, 11:52 AM   #9
I didn't see an attachment option on the quick reply. I see it on the normal reply. Here.
Old 03-29-2021, 11:56 AM   #10
Steering gear box.
Looks like the side cover is weeping fluid. Steering will still work so long as you maintain the fluid level.
As far as your brakes are concerned, you should verify you have air to your treadle valve first, but the valve is likely faulty.
