Go Back   School Bus Conversion Resources > Skoolie Tech > Mechanical and Drivetrains
Click Here to Login
Old 04-13-2019, 04:07 PM   #1
Engine: 5.9L Cummins
Radiator blower fan always comes on the first time I pull onto the highway
I dunno if this is normal? I have a 5.9L cummins turbo diesel with an allison at545 transmission.
Regardless of it being hot or cold, every time I first go on the highway, the engine will heat up to over 220 and then the cooling fan will turn on for about 2-3 minutes, bring it back down to 210 and then it will shut off.
Every time.
Is this normal?
-cycosis- is offline   Reply With Quote
Old 04-13-2019, 05:50 PM   #2
Does it maintain temp after the initial heat up period? if so, sounds like a bad thermostat. 220 is hotter than I like to see during normal use.
