Old 06-28-2022, 06:20 PM   #1
Regen
Mbe 900 in a 2008 c2 no regen switch
How do you do a regen without spending big bucks
As the bus is asking for one
Short bus dweller is offline   Reply With Quote
Old 06-29-2022, 11:19 AM   #2
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
Engine: DT466e 7.6L 245hp | Allison 3000PTS
Most DPF buses will do an active or driving regen when at operating temperature and while running at highway speeds. Or there's usually a switch somewhere for a parked regen. Once the DPF is significantly plugged then the driving one won't go and you're forced to do a parked regen. My 2008 IC FE300 had a switch in the drivers area for it. I recall some Gillig low-floor buses I drove in college the switch was in the engine compartment.
Dbacks2k4 is offline   Reply With Quote
Old 06-30-2022, 05:25 PM   #3
Oh well
See that’s why I can’t find out how to regen my bus a 2008 Thomas c2 with a Mercedes mbe900 what with a freightliner chassis no one knows
It didn’t come with a switch to regen
Has to be away
Must be me
Old 06-30-2022, 05:28 PM   #4
Yup but at 609 a gallon not driving as much
Maybe a parked regen is what I want
And what the bus is asking for a parked regen
But how IT DONT A HAVE A REGEN switch
Feel me
Old 06-30-2022, 06:53 PM   #5
I havent worked on a mercedes.. it may be something thats in a menu on the LCD odometer screen if you have one.. I have seen this to be the case on some of the CAT engines in freightliner box trucks...
Old 07-10-2022, 02:05 PM   #6
Chassis: RE300
Rated Cap: 76
Try this link and post:
https://mechanicshub.com/diesel-engi...0is%20required
The author mentions software, but it also appears there may be a procedure for initiating via ignition switch combo.
Don’t have an MBE, but maybe this will help!
Good luck!
Jeremy
jjaj823 is offline   Reply With Quote
