Old 03-10-2020, 05:03 PM   #21
Chassis: IH
Originally Posted by kidharris View Post
Well, they use gas powered high cfm high psi compressors costing thousands of dollars compared to my $40 HF compressor and their bead blasters are lightweight aluminum and cost much more. Like comparing an ant to an elephant.
True they use much larger, faster, more powerful and expensive air compressors, but the bead blasters are all very similar (and I've seen plenty of steel ones, even home made ones in use.) I can honestly say I have no less than four air compressors - one of those El Cheapo cigarette lighter ones, a 20 gallon portable, a 60 gallon shop compressor, and of course the one on the bus itself.
Old 03-10-2020, 05:14 PM   #22
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Originally Posted by TheHubbardBus View Post
Gracias to all. Absolutely no problems. Took surface streets the whole way.
Our new tires are sick!
Our buses must know when we are getting new tires. One of our rear tires (outer) went flat a week or so before we were due to get our new ones mounted. I ended up driving it the 10 miles to the shop (fully converted, approx 20,000 lbs) without an issue. Rural back roads with some city.
We ended up with the Falken BI850. So far so good.
Dave
Old 03-10-2020, 05:41 PM   #23
Pretty sure both my local tire guys use these-
https://www.homedepot.com/p/Steel-Co...0010/301119995
Old 03-11-2020, 02:51 PM   #24
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Those are bad-ass, @ermracing. If I had known they existed they'd have been contenders for sure! Have you tested them out in questionable traction situations yet?
Wish I could fault our bus for breaking a bead in anticipation Sadly it was solely my doing. Note to self: Trying to level a bus by airing down the tires is no bueno
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 03-11-2020, 04:20 PM   #25
ermracing's Avatar
A 20-ton bottle jack is about $30 and/or some slabs of 2x8's would work.
We haven't really tested the Falkens on rough stuff yet. The only outing we have taken with them is on some snow covered dirt roads, but as you can see in my profile picture, we had a little help with traction.....
Dave
