8 wires sounds odd. Must be set up like GM cars of old. Attached to your starter will be a small can looking thing, almost like a small starter. That is the starter solenoid. There should be one large lug, like 3/8" bolt, that has a battery cable sized wire attached to it. There may be other wires of various size attached to this as well, disregard those. There should be a small lug with a single small gauge wire attached to it. That is the wire in question. Remove that wire and hook up the batteries, key off, and see if it still cranks. If it does, that solenoid needs replace or rebuild. If it doesn't crank, leave the batteries hooked up and test the wire you removed. That should only have power when the key is being held in the crank position. If it has constant power, you will need to trace it back to it's source and fix whatever is giving it constant power.
