Originally Posted by Jolly Roger bus 223
thanks chris
you were the best one to be on this thread.
i just bumped. for the OP.
if you dont mind i might PM you monday if i cant figure it out about some all in one building components not play together?
like lonworks on one system a carel controller and a johnson bacnet/mstp setup and a sierra field server for an LG gateway to 5 seperate VRF systems?
AAARGH
they dont like each other and i dont like them
oh yeah all the various building automation systems not playing nice with each other.. I remember those days.. those EARLY days of DDC when I was in the HVAC business.. Barber coleman didnt talk nice to honeywell, johnson didnt talk to anyone.. and white rodgers was out there sort of ..
oh yeah and there was Liebert.. off in their own elite-ist world..
at some point Daikin came along as the only VRV system builrt for mild to wild.. at least their stuff was pretty easy and lots of people buolt attachments to snag their protocols..
I just serviced a Broken Daikin VRV-III for a friewnd of mine who bought an apartment building that has one in it.. he is cussing it badly right now (and so am I).. said VRV is in a 4 unit building, each unit has 3 coils... so theres 12 coils.. when i arrived and put my gauges on im like "dude we have a leak...someplace within the walls / ceilings (or just maybe) the outdoor unit we have a freon leak....".... then comes the issue.. the unit coils are installed within hard ceilings of the apartment below.. (so the vents can be in the floors)... damned if I didnt get lucky and the leak was in a coil hung in the drop-ceiling basement... the dark spot in a ceiling tile was a tip off.. sure enough oil dripping from a liquid line... my buddy was dancing in joy that I didnt have to charge him massive hours getting into each residents ceilings....
except its down 40 lbs of freon and R410A is $25 / lb right now.... the pitfalls of VRV.... im running an Intesis gateway device on that VRV for internet connectivity.. otherwise it would talk LON if its like the others ive worked on.. Intesis makes some really great products for tying together various automation systems / data busses..
that Intesis device saved him from losing 80 lbs of freon down to 40.. a half full VRV will run just fine but the operationals are way off on it even though some of the aones will heat and cool perfectly normal...
the Daikin has proper "king" isolation valves on it which allowed me to pump the zone flat then close off the condensing unit and have the service ports open to the zone piping so I could fix the leak and evacuate properly...
fun stuff!!
I sometimes miss havign a career in the HVAC industry.. although i wpuldnt have been saying that if id have needed to open up all 14 units to find the leak...
