Old 09-22-2022, 10:16 AM   #1
T444e STARTING BUT CUTTING OUT AFTER A MINUTE OR TWO
Hello there,
My bus has been sitting for 6 months and yesterdayís I tried to move it and ran into some issues.
It started up fine and we got it about 5 miles down the road, initially it sounded low on diesel so I drove and got 5 gallons in a Jerry can. Once that was in it sounded great and made it to the gas station where I filled it up.
It then drove fine for another couple miles and then just cut out again, when I tried to restart it could only stay on for a few minutes before cutting out. But it starts everytime.
I managed to get it into someoneís farm but Iím not sure what to do, it obviously seems like itís not getting fuel. The fuel filter is clean and the fuel in there looks clean so itís making it thereÖ.
Any thoughts? I would happily pay someone for a phone call who knows these engines well?
Iíve been recommended to bleed the fuel injectors in case there is air in the system, so Iím going to try that this morning. But if anyone has any words of wisdom please feel free to reach out on 4158589101. Based in Austin texas, anyone whoís out here who would come investigate I can give some $ to?
Thanks so much in advance
Very stressed, hot and bothered bus owner person. 😂
Abbyapple is offline   Reply With Quote
Old 09-22-2022, 10:35 AM   #2
ewo1's Avatar
Originally Posted by Abbyapple View Post
Hello there,
I would first go ahead and replace the fuel filters... maybe they are gummed up?
In any event this would be step one towards any troubleshooting. Go to eliminate the most obvious things first.
Old 09-22-2022, 11:09 AM   #3
Will do that now, though it looks pretty clean and the fuel in there is cleanÖ but you never know
X
Old 09-22-2022, 12:43 PM   #4
def replace the filters... it also could be its still so low on fuel (dip tube might be cracked) that its sucking some air esp as you ropund corners or stop and go and fuel sloshes around..
there is no bleeding the injectors, the are HEUI injectors and the Lift pump (mechanical in the engine valley) needs ot provide 47-72 PSI of fuel to the rail lines that go in the heads..
make sure you arent Low on engine oil... low engine oil or low dash oil PSI can run the HPOP out of oil which controls your injectors.. I dont think thats your issue since you said it starts right up..
when it dies is the WARN light lit before you cycle the key off? if so you might want to see if you can get any Flash-codes out of the computer by pressing the Diagnostics Button under the dash (it will be next to the round grey 6/9 pin diagnostic connector..
it will flash the WARN light in sequeances to get "codes".. and between each code it will flash the oil / temp Red warning light.. this shoiuld be done key on, engine Not running..
Old 09-22-2022, 04:27 PM   #5
So the codes I got are 615 and 622
I think they’re both related to ECM
all fluids are good, waiting on a new cam sensor just because it sounds like they go bad a lot….
This is hurting my brain ��
Old 09-22-2022, 04:29 PM   #6
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
The jerry can was just to get him to a fuel station where he did fill it up.
HamSkoolie is offline   Reply With Quote
Old 09-22-2022, 05:32 PM   #7
I missed the part where he filled it up.
615 and 622 are related to the Memory in the ECM getting corrupted.. I see these codes most often when there is a power issue.. ie a Loose ECM BAT wire.. even if the key is on and the engine is running a loss of the ECM BAT (always-on Battery circuit) the ECM will shut down.. if its momentary the ECM will reboot.. lights will flash back on momentarily and ifthe engine is still spinning (ie manual transmission or lockup still engaged on a newer auto) then the engine will just start running again.. if its on an AT545 or oother unlocked auto and stops spinning then it wont restart on its own..
its possible a circuit is going bad inside the ECM causing it to shut down when it warms up..
I would look for loose wiring for the small ECM wires going to the battery and also the wires from battery to starter.. and also make sure the fuses in the fise box on the dash (chassis fuses) are making good contact.. I had a couple on my busses where the plastic is going bad and the fuse conact pushed down inside far enough the contact was intermittent..
just something to try thats easy first..
Old 09-22-2022, 05:37 PM   #8
So I’m currently the the bus where the wires come from back of batteries, where it goes up into the engine the wires and plugs are all super duper caked in oil and filth, should I unplug and clean them all off?
Will look at other loose wires too
