Old 08-07-2020, 04:09 PM   #1
Thomas Saf-T Liner Dash Light
Hi,
I have a 2004 Saf-T liner and it sometimes gives me a warning light that looks like a circle with three lines sticking out of it. Can anybody tell me what it is? I’ve searched high and low for an operators manual.
RollinThunder is offline   Reply With Quote
Old 08-10-2020, 04:23 PM   #2
Peterjk's Avatar
Year: 2005
Engine: Cat C7 300/800
Rated Cap: 31
Originally Posted by RollinThunder View Post
Hi,
Picture might help ? Mine is a 2005.
Peterjk is offline   Reply With Quote
Old 08-11-2020, 08:11 PM   #3
bp1791-unleashed's Avatar
Chassis: Saf-T-Liner
Engine: CAT 3126E210
Rated Cap: 33,050 pounds
Are you sure it is a circle?
There are some high-beam indicators that look kinda like what you are describing, and also some fog light indicators as well. It's more a very rounded triangle with lines "projecting" out from it, sometimes straight, sometimes angled, sometimes squiggly with a vertical line through them, sometimes to the left, sometimes to the right. That's just from some basic image searching on google.
A pic would definitely help, if you could link it here.
bp1791-unleashed is offline   Reply With Quote
Old 10-08-2020, 09:27 PM   #4
Hi,
Were you ever able to get this figured out? I'm having the same issue.
Ducci is offline   Reply With Quote
Old 10-08-2020, 09:31 PM   #5
Truthseeker4449's Avatar
Chassis: MVP ER
Engine: CAT 3126
Is this your light?
If so it means the air pressure in the primary and/or secondary tanks is low. The light should go out once you built up to about 80 psi in both tanks. This is normal, especially if starting the bus for the first time that day. If you see this light while driving you need to pull over before your brakes give out or the parking brake "unexpectedly" comes on.
Truthseeker4449 is offline   Reply With Quote
Old 10-08-2020, 09:33 PM   #6
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
If so, I hope they didn't find out the hard way...
thomas 2004
