I have a front engine flatnose bus, 2002 amtran with a DT466e.
My tires are worn out and probably ancient, although I couldn't find the date code on them, but I am having a bad wear problem where the outside shoulder is wearing out very noticeably on the front tires.
I have heard that front engine busses are murder on steer tires, and one shop said I had river wear on those tires, but that doesn't line up with what I am seeing. that being said, I have no idea what I am talking about.
The same shop said my kingpins were worn, but honestly I didn't trust them at all, and my bus has about 10k miles since the kingpins were inspected and said to be fine.
but.. tire wear, kingpins, I guess that makes sense?
I had the alignment done but it didn't seem to slow down the outer edge wear much.
I have to get one more 2000 mile trip outta this bus before parking it for a while and I would love to not do the kingpins if I don't absolutely have to, so I am thinking about buying just a couple of double coins for the front and seeing what happens.
So questions: anyone experience this kind of tire wear before and if so what may fix it? Second, could this be normalish wear and I am making myself crazy? third, if my kingpins are worn enough to wear tires funny am I stupid to drive 2K miles on them? Fourth: what does a kingpin job typically cost? And fifth, can I check the kingpins myself if I figure out how to get the bus off the ground?
Okay, sixth question! Any reason not to have a tire shop just rotate the tire on the rim so I have a virgin outside just for this last trip?
pics:
https://imgur.com/a/oKtWlTr
