While the Power Strokes aren't "that bad" compared to the IDI's (problem addressed), they are still highly susceptible to "cavitation". Since the result of a "cavitation" failure is rebuild or replace, every step should be taken to be nice to the system. As the vast majority of non fleet (and even some fleet) users do not stay on top of maintenance.
Just this week I was asked to look at a 3 year old SUV that was having driveability issues and the owner thought it was the transmission because the RPM's were fluctuating and the car didn't seem to accelerate properly.
I started with a fluids check.
Trans fluid pink, sufficiently full for a cold check, not burned, no grit
Engine oil, tip of the stick showed mild corrosion discoloration & ZERO OIL
Added THREE QUARTS to the 5 (with filter change) system.
Vehicle test drove just fine and transmission fluid level was perfect after warmup and recheck.
Million mile of 500k mile ELC's that eliminate the "cavitation" issue are well worth it and in THIS mechanics opinion NOT an option.
You may have noticed the use of quote marks around the word cavitation. While it is the proper word, most people think of cavitation as Webster's first definition. The one that applies to ships propellers and other moving structures in a liquid with the cavitation bubbles acting abrasively upon the structure. Webster's definition 1 is:
- The sudden formation and collapse of low-pressure bubbles in liquids by means of mechanical forces, such as those resulting from rotation of a marine propeller.
However, in the context of the 7.3 cooling system, Webster's 2nd definition is the justification for the use of "cavitation".
2. The pitting of a solid surface.
