Old 11-22-2021, 11:52 PM   #1
lcm0027's Avatar
To much rust?
Iíve been detailing my Cummins and came across parts that are rusty a little more than I am sure of. What do you guys think. To much rust or is it okay? What should I spray on it? IMG_2964.jpg
lcm0027 is offline   Reply With Quote
Old 11-22-2021, 11:54 PM   #2
lcm0027's Avatar
IMG_2969.jpgAnother angle
Old 11-23-2021, 10:17 AM   #3
Zork's Avatar
Year: 2008
Coachwork: IH
Chassis: IC SB CE-300 39ft
Engine: DT466 w/Allison 2500
Rated Cap: 29500
Originally Posted by lcm0027 View Post
Attachment 62568Another angle
These are pictures of the engine block?
Zork is offline   Reply With Quote
Old 11-23-2021, 11:28 AM   #4
The scaling on that block looks like it's been under water, for a long time.
Old 11-23-2021, 11:47 AM   #5
lcm0027's Avatar
Runs like a champ. Only 99k miles. Iíve got some POR15 on the way.
Old 11-23-2021, 11:50 AM   #6
Zork's Avatar
Year: 2008
Coachwork: IH
Rated Cap: 29500
You'll get the same protection using liberal, regular applications of WD-40. That is its purpose, preventing corrosion (and not lubrication). And you'll keep more of your money.
Old 11-23-2021, 11:51 AM   #7
lcm0027's Avatar
So youíd recommend spraying it down with WD40? Should I continue to chip away at all that rust?
Old 11-23-2021, 11:55 AM   #8
Zork's Avatar
Year: 2008
Coachwork: IH
Rated Cap: 29500
Chip??? No, use a wire brush. And spray it down regularly and copiously with WD-40, then let it dry. The film it leaves behind is what protects from corrosion, it's what the product is designed to do (WD = Water Displacement). Works wonders as well on aircraft in places close to the ocean, and on boats. Just don't put it where you don't want any dust to accumulate. The film attracts it and gums everything up.
Old 11-23-2021, 12:07 PM   #9
lcm0027's Avatar
Iíve heard WD40 is widely misunderstood as a lube and not for water displacement like you stated. I still think Iím going to use the 3 step POR15 rust stuff on these really bad spots but I will use WD40 on these other parts around the bus that has minor rust that I donít want to do a 3step process.
Old 11-23-2021, 02:22 PM   #10
Wire brush, Ospho then paint!
Thatís what I do on my bus.
